Does anyone know if it's possible to pull a speedometer from a TBI Blazer and plug it in to a pre-TBI dash in order to get the VSS signal out of it? If so, does it just wire straight from the speedo to the ECM?
Confusing. How does cruise control work with no measurement of speed?
Is the DRAC used to drive the speedometer or also the ECM?
I'd be okay spending $75 on one of the VSS things that goes in-line with the cable, but I need to understand how it's wired. #1 on this page:
http://www.jagsthatrun.com/Pages/SpeedSensors_Speedometer.html
Would I just ground one wire and send the other to the ECM?
I'm assuming you have a speedo cable correct? The cheapest and easiest way for you to go would be the inline speed sensor.
How is it wired up?
