Vss
possum70
Mebane, NC
Well, Moira's speedometer doesn't work. New cable, doesn't work. Put a drill on the cable and she went @55 mph. So I'm guessing whatever is in the T-case isn't working.
But from what I read I have to buy a specific piece matched to my tire size and gear ratio. 33" and 3.73. Where can I find this part?
possum
Not VSS, you are looking for the drive and/or driven gears in the trans. Not sure what is still being sold, I thought this stuff was drying up, but check with TCI. I recall they also had a chart for the speedo gears.
Not sure where there is a gear calc for the speedo gears if you don't know what % you are off currently. :(
Is this on your 78 Blazer? If so and you have cruise control then there are two speedo cables involved, one goes from the t-case to the transducer for the cruise control and the other goes from the transducer to the speedo. It is very common to have a bad transducer causing this issue. In the even you do have cruise control remove the cable from the t-case and run it with a drill, if the speedo doesn't work then remove the cable from the transducer going to the speedo and spin it (guessing you already did this cable as you said it read 55mph).
I dont know where you can buy new. Probably google "speedometer gear replacement" and go from there.
