want to drill and tap boss on np205
I can always once it's gutted take it to a machine shop and have it done to the size I need. I may not even need to empty the case for the them to do it. It will just be heavier.
Just need exact specs I venture
Might be cheaper, tap handles I was shopping for were $80-100+ pre COVID. Plus still need the tap and drill bit, probably @ $40 together
Don't cheap out on taps, get good ones. If you snap a tap it is total pita to get out.
Wes’s thread size is spot on for the holes in any of my drilled cases.
Ya’ might not want to take a partially assembled case to a shop and have it drilled - metal shavings everywhere and the guy doing the work is not gonna be happy about the added nut-sack drop factor. Bare case would be the way to do it.
5/8" x 11 tpi. Tap you by will determine the drill size. Am not home so can't go to shop and look. It is going to be 17/32" guessing
When I take it the shop I ask them to drill this size hole and tap it to 17/32?
How deep all the way through or 1 1/4 deep? And how far apart the holes? How I get that measurement
No not all the way through. I think 3/4" deep is plenty. I am not sure how thick the casting is there. I will later this week. Mine is drilled and tapped and no torque rod yet. I need to fab my own.
As Paul mentions earlier in the thread…3-3/8 c/c for the holes. 5/8-11 thread size.
My old support rod has elongated holes
I would not do any drilling on your case until you have mocked up the torque bar to your tranny. Still if it were me I would be looking for another Np205 that has the holes.
@Wes Harden @tarussell
To tap/drill etc?
An industry standard ( they are variables and exceptions ) is 1-1/2 thread depth engagement of the diameter of the retaining hardware ;but you are working with a limited amount of material until you possibly make it a through hole instead of a blind one ( blind hole is what you want but I think there is enough material there to keep ya safe ).
You can mark off the proper dimension on your drill bit with tape as a guide to keep you from drilling to deep.
Also keep in mind that the tap you have there is not a bottom/finishing tap and the very bottom of your engagement will not have proper threads - but if you have enough hole depth to drill a little deeper than what thread depth is needed all will be well.
Keep in mind that a machinist shop can do this for most likely less money than acquiring another drilled case plus freight charges ( you had mentioned this in one of these post lately ).
Also don’t let this give ya’ a headache - if you are not wheeling hard where sudden high traction and plenty of frame flex is the plan than this bar is not a 100% necessary.
That being said I am a fan of these bars in any 4WD but on the average user most cases it wouldn’t matter if they were there or not. I think they are good insurance and effective but don’t be afraid of light wheeling without one.
I think the torque bars first appeared in 1978. In 1972 was the side braces. From 1973-1977 did GM have any transfer case brace?
My 77 was missing all the braces, and had the wrong type case transmission in it when I got it.
So many times lazy mechanics leave out important items just because it's inconvenient
I think you are right about 78 possibly being the first year of the torque bar brace on some applications.
I did have a 74 K/20 with a side torque mount ( early Energy Suspension catalogs showed it was listed up to 75 but that doesn’t prove or disprove anything ).
The GM trucks I’ve worked on with iron T-cases go along with 69~75 having the side mounts and never saw any brace or mounts ( stick or auto ) from 76 & 77 and 78 the brace started showing up on auto trans trucks and stick trucks by 1980 but that seems to be hit and miss through the 80’s.
Also had a 77 K/10 350/465/205 with no brace and no drilled holes in the case.
Had a 83 GMC K-3500 Crew Cab 454/465/205 with the side brace and the lower bell housing to motor mount plate bars.
Parts trucks - a 79 K/30 Crew Cab 292/TH400/203 with a brace and bell bars ; and a 78 K/30 Cab Chassis Wrecker 292/465/205 with no brace , no bell bars and not drilled case .
Friends 78 K/5 350/TH350/203 no brace and not drilled.
Friends 78 K/10 400/TH350/203 with brace but no bell bars.
A 77 K/15 parts truck 400/TH350/203 no brace and not drilled.
Another 77 K/10 parts truck 350/465/205 no brace and not drilled.
And my current 83 K-30 454/TH400/205 has the brace and bell bars as well.
Used a shop truck a 78 K/20 292/456/205 no braces and not drilled.
Local fire support truck 81 K-30 350/TH400/205 had the brace and bell bars.
IIRC NVRENU’F’s old 91 V-3500 350/4L80E/205 had brace and bell bars.
John’s buddy with a 80 K/25 400/TH400/205 had the brace and bell bars.
Local body shop tow truck 81 K-30 454/465/205 had the brace and bell bars.
Knew a guy with an 88 V-3500 350/465/205 came with the brace and bell bars.
A friends 85 K-30 454/TH400/205 had brace and bell bars.
Never saw any mention in the books of the brace before 78 or anything about the side mounts after 74/75-ish.
Seems like the mid to late 70’s three pedaled trucks didn’t get the brace….anybody know for certain if they ever saw an original equipment brace on any 76 & 77 trucks or 78 & 79 465/205 trucks ?
@tarussell I bought a spare 4spd/205 assembly once, the tag on the 205 said ‘79 and it was not drilled on the side. I always thought it was strange that case wasn’t drilled but my ‘80 K10’s 205 is drilled (it’s in my Blazer).
What about that 84 K-30 Cab Chassis that ya’ got your first front D60 out of ?
I don’t remember. It was a 4spd/205 but I don’t even remember what happened to that combo.
Wasn’t that the one with the 10-spline coupler slap smooth worn out ?
That truck was worked real hard all it’s life!
On the 78 K5 that I own I know for a fact that it was built from the factory with a brace for the NP203-th350.
It is interesting that GM progressed thru three iterations (side frame brace->no brace->torque rod w/bell bars). Logic would be that the best design is what GM ended up with. I sure wish we had some context to why GM made these changes.
I've seen a few posts where guys just drilled through and then use thread sealer on the bolts...
Im may just try and drill and tap it. If I mess up a shop can do it im sure. We'll see. Seems you can only really drill an inch or so anyway, wes was saying 3/4 bolt length.
Im pretty's sure on my 203 the bolt is longer than 3/4 length I may take one out and just verify.
