9" Jimmy
I'm looking for axles in or near cen cal that will drop into my 75 1/2 ton jimmy. At least 4.10's and a 12 bolt or 14 rear.
Will 4.09 fronts work with 4.10 rears? Are the 4.09's installed? And they'll drop right in with my setup right? If yes to everything, sounds good.I have a D44 front and a set of 4.09 gears for it, and I have a 14bsf rear or a D60FFrear 4.10 gears. $400 for the set with the 14bsf, $500 if it's the D60 rear
I can also deliver to Hanford for a few bucks.
I should go with 8 lugs, but I have two sets of rims that are 6 lug. So six lug, unless you have a set of 15x10-15x12 8 lugs going with them...You looking for an 8 lug or 6 lug?
