Wanted, axles in Central Cali
9" Jimmy
Hanford, CA
I'm looking for axles in or near cen cal that will drop into my 75 1/2 ton jimmy. At least 4.10's and a 12 bolt or 14 rear.
I have a D44 front and a set of 4.09 gears for it, and I have a 14bsf rear or a D60FFrear 4.10 gears. $400 for the set with the 14bsf, $500 if it's the D60 rear
I can also deliver to Hanford for a few bucks.
Will 4.09 fronts work with 4.10 rears? Are the 4.09's installed? And they'll drop right in with my setup right? If yes to everything, sounds good.
I figured that might be the case so you might not want my setup. Unfortunately, I'm now convinced my new 4.10 axles should have been 4.56's at a minimum.
