Magikal
warn m8000I winch. should all four solenoid , receive power when the switch on the controller is pressed? none of the solenoid click. was thinking maybe the ground isn't hooked up ( common wire from other side of the solenoids) haven't had much time to look at it yet so it may be something quite simple. winch got tore off bumper, taking a terminal out of a solenoid. replaced the one solenoid and now nothing happens when I press the controller. solenoid sat in a dead short fir appx 30 sec when accident happened before I could un hook the battery. I did jump the motor to verify it actually works still and that part is all good. thanks for any education you all are about to post on thus thread for me!
