come on,that brought the funnay!
no?
no?
no?
come on,that brought the funnay!no?
I used Herculiner. Which is suppose to be the quality roll on stuff.
I think its the issue of it coming up from the bottom but I still wouldnt trust just bedliner to encapsulate rust and lock it up like por15 will.
well, don't expect "i hit it with a wirewheel" to do squat for ya, except postpone the inevitable......
there are obviously varying degrees on how to deal with, and prevent rust.... first and foremost is not to have it there... whether that's by cutting out, grinding, media blasting or even acid... sandblasted metal? thats "clean" steel.... wire wheeling just knocks off the top stuff and burnishes the rest....
if your going to do that, than you have to live with the potentiality of it returning... whether you put an encapsilator on it, or converter... i tend to prefer converters in those circumstances... encapsilators tend to perform better when you can coat a whole item...
nobody wants to do the work... everyone wants to slather some stuff on and cover it up... instead of putting sooooo much time into reading the web and contemplating different snake-oils, everyone should do the labor to remove the damn rust... a proper coating system over clean steel will last a LONG time.... metal conditioners, good primer, etc are made for a reason.. a line-x'd exterior tho it may fade can be made to last a LONG time, if your prior coatings are done correctly and of good quality... that means proper grit sanding, dewaxing, etc...
oh, and tho there are many decent products in my business, boats, don't assume that "it's marine, designed for saltwater" necessarily means squat.... a catalyzed car paint is far superior to a non-catalyzed marine product.... Awlgrip marine paint, yeah, polyester based, catalyzed resin, tough as nails... Brightsides marine paint? ain't no better than standard Rustoleum....
So cut, weld, zinc, por15 and then liner? (Who makes a good liner?)
It's funny, I could just about feel you roll your eyes and sigh before writing that.
but i try to maintain...ideally.. clean steel, zinc, urethane primer, urethane paint then bedliner...
you guys have GOT to get POR15 out your brain...
you could bedline right over a decent primer.. but a good paint coat helps seal it up all the better...
