Warpage tolerance specs for small blocks:
Does anyone know the warpage tolerance specs for a small block ( heads and block).
Or where i can find them?
I would highly recommend that you resurface any head with more than .003" warpage. The block i've never found to be an issue unless you blew a head gasket and kept driving it until it burned a path between a couple cylinders.
