The coilover conversion section is up on the website!
Snap some pictures for me, send them to my email and we'll get something figured out for you.
The engine cage/shock hoop system will be very universal since the underhood area on these trucks varies a lot. We started on a bolt on engine cage and it became obvious it was not going to fit much at all beyond the "jig" vehicle.
OK, that makes sense and does make it a lot easier for you guys when building a kit.
are the axle brackets weld on or bolt on? Trying to see how it works.
They weld to the axle, there is no real way to combat the forces of a traction bar or links without welding to the axle.
We know that people would prefer bolt on and this is as close as it gets while still making it strong and reliable.
We have pieces setup for an engine crossmember but like Stephen said there really isn't a way to produce one piece and make it fit for everyone. So that piece is sort of on a case by case basis, it's pretty easy to make it fit on a typical small block but a turbo diesel is a different beast. Far from impossible but probably a little more than a straight piece of tube.
.They weld to the axle, there is no real way to combat the forces of a traction bar or links without welding to the axle.
how much lift does this kit give you? and how far can you adjust it?
