Hey guys. Me again. I finally have enough together to attempt to start the jimmy! Woohoo.
But as the title states, my starter is super weak, turns over sometimes then slows down then clicks then will turn over another time or two, then nothing.
I have a good yellowtop optima battery fully charged. And now a new starter
I was thinking maybe its a ground issue, I have a ground (big nature size wire) going from around the fuel pump area to the frame, another big ground from the frame to the battery. A ground strap from the battery to the fender (just added this, it didn't seem to make any difference), and a ground strap from back of engine block to the firewall.
Where else should I check? And where else should I check or add ground connections? I'm losing voltage somewhere right?
