I went to start the truck as normal and it turned slightly then stopped but not instantly. It felt like it had hydrauliced. So, 'cause I was in a hurry and thinking 'it couldn't've hydrauliced'....I tried again. Same thing
For some reason, and I still don't know why, I took it out of Park into R and back into P, tried it again (well why would it hydraulic?
) and it started as normal
So, it either did hydraulic and cleared itself, or is it possible for the TCC to engage at engine off or on?? I went for a 20 mile drive and all seemed well so if it did hydraulic, it didn't do any damage. I'll check the coolant and oil tomorrow in daylight incase a head gasket has gone.
Any alternative ideas?
You could buy to Optimas over here for that. At least it sounds like you found the problem. Guess it wasnt confused about being on the wrong side of the pond.
