Weird problem - a simple fix?
Willie G
Newbie
Parker, CO
OK, some background - 1990 Suburban, 454 TBI - passed emissions on Saturday (running well, in other words).
On Sunday while trying to fix the dome lights I notice there is no fuse in the Horn/Dome slot. I was letting the engine warm up, so I just plugged in a fuse. The truck died immediately and will not start.
Looking at the diagnostic flowchart on Chevy Thunder, I have power to ECM pins A6 and C16 but not to B1.
Can I use a jumper from A6/C16 to B1 as a temporary fix?
Your thoughts/suggestions?
Thanks in advance.
I thought A6 was 12 Volts switched from the ignition switch?:confused: Check to see if A6 has power with the ignition switch ON / OFF. I would not jumper to A6.:eek1:
I seem to remember B1 / C16 were 12 Volts from the battery. Seems very odd that C16 would have 12 volts from the battery and B1 does not have 12 volts from the battery.:confused: Well maybe it would be OK to jumper B1 / C16, but I'd disconnect the "+" cable from the battery and use an OHM meter from the "+" battery cable to B1 / C16, just to make sure there is a problem with the B1 wire?:confused: I would also OHM meter the wires from B1 / C16. Be sure to unplug the ECM from the wire harness if you use an OHM meter.:doah:
dave w
