misweetrevenge
Registered Member
So the only window that is functional at normal speed is my drivers window which I'm pretty sure the motors are just getting weak from age so thats what I'm here for.
My issue is my rear passenger window. With the driver switch it goes down (slowly but its old) and will slowly go up but stops about an inch from the top and I'll lose control of it through the driver switch. Now if I go over there and use the switch on the door itself its just fine. I found a switch at the junkyard and I swapped them out with absolutely no change. Any ideas?
Also, My barn door sometimes requires the key to stay in the unlock position to open the door. If I unlock it with the key and then return it to neutral to pull it out it relocks. And most of the time the lock switch that is used to lock the truck doors doesn't lock or unlock the barn door. Any ideas?
Thanks for any help guys and gals.
