Weird Window Issue On 91 Burb
Do you recall how to get it out? Iv taken the panel off the door and the interior window sweep is off as well. There's 2 nuts by the coil that I can see. I don't see any rivets or anything else that is holding it place. What else is there to pull t out? I'd like to pull it put and clean/grease the tracks at the same time as I cleaned the coil.
You just have to remove the entire regulator assembly as one piece. It is a bit tricky, but you need to manipulate it to fit through the small door access opening.
