Weld in Steering Brace - $65 shipped
jjlaughner
3/4 ton status
Indiana
Weld in Steering Brace - $65 shipped -pending
New sitting a USPS box ready to roll. bottom and side plates both, long side plate like from ORD (probley was from ORD originally)
Paypal is good! :waytogo:
should fit ’73 to ‘87 pickups (up to ’91 Blazers) GM F/S 4wd
Can you post pics? Does it go on the inside or outside of the frame. Thanks Jason
outside and bottom I believe
Bolt it inplace of the box, hammer it out till it fits snug, clamps all around, weld in the holes, then around the outside where the round sections are, leaving inch gaps between the welds (same with the bottom). Requires some fitting.
http://www.offroaddesign.com/catalog/steeringkit.htm :waytogo:
There was a video that use to be up on here of someone welding it on, I found the post the video is no longer hosted (its was a 2004 post).
