Welder opinions
MTBLAZER89
3/4 ton status
Kalispell, MT
I am looking at getting a welder. I welded in high school, but not since then. This will be used for small projects until I get better at it then on to bigger things. I have $500, but would like to spend around $400. I can get a factory reconed Hobart 135 for $379, or the Hobart 140 New for $431. I am leaning towards the 140 because of the "welds 1/4" in a single pass" over the 135's 3/16" capability, but don't know if I really need that much right now. What do you guys think about these welders, or do you have any other good advice. Thanks /forums/images/graemlins/waytogo.gif /forums/images/graemlins/peace.gif
I'd go with the bigger one of the two. 1/4" material is pretty commonly used so its nice to have that capacity. Even then the 1/4" thick material is at the far end of that machines capability, but with a little preparation it will do a good job of welding it as long as you have a good power supply for it like a dedicated circuit that supplies at least 30 amps.
I'm not familiar with the warranties on hobarts but from what I have heard they are pretty good. Aren't they basically a Miller with a different wrapper?
/forums/images/graemlins/thumb.gif
Get the one with the bigger dudy cycle! I used a little lincoln a few times on 1/4" stuff and it worked OK, but could use some more penetration!
Are these Hobarts 110 or 220? I have a 110 Lincoln and I hate it! It just doesn't produce enough heat for most of my jobs. Our 220 lincoln works much better but I prefer our engine powered stick welder, sticks seem to penetrate better with thick material than a wire machine. /forums/images/graemlins/thinking.gif
Whatever you get be sure to get a bottle too. It makes welds soooooooooooo much nicer with the inert gas instead of flux core. /forums/images/graemlins/smile.gif
OK now the 175 is looking pretty tempting. $459 for it reconditioned with Hobart one yr warranty /forums/images/graemlins/dunno.gif
lincoln 135. 5/16 in 1 pass. ebay for 400 bux shipped /forums/images/graemlins/peace.gif
[ QUOTE ]
[/ QUOTE ]Thats the one I have and I hate it! /forums/images/graemlins/angryfire.gif
can i ask why you hate it? i like it better then my shops millermattic 210v
search used, the smaller welders are always available as once you buy one you learn that you need a bigger welder
buy the biggest one you can get
[ QUOTE ]
[/ QUOTE ]
It also doesn't penetrate as well.
So far I have only used my welder with flux core wire (but I have MIG welded before also). I welded the 1" thick plates that hold my hydro ram on the axle with it and it penetrated fine. My Bambar was welded onto the axle housing iwth the same welder.
There isn't going to be any noticable difference between the 135 and the 140.....they're the same unit, one is just the updated model. /forums/images/graemlins/waytogo.gif
I'd get yourself the cheaper of the two Hobarts and go. Get a bigger MIG later.
I was so heart-set on getting the 175, but I found this Hobart 135 (well a CK5 member pointed it out to me) for $229 and I couldn't pass it up. I got it, started burning some metal, and honestly, nothing can replace a good 110v wire feed. You can take it anywhere and plug it right in. I've taken it to friend's houses, and used it to fab my bambar, fix my exhaust, weld up a 10 bolt rear axle, install my hydro assist, etc.
I have not yet been limited by my 110 volt machine's capability. Honestly, I'm glad I didn't get the 175. Even my 133 lbs with a bum knee can still drag my little 135 everywhere I need to take it. I have a 100' long #10 extension cord and I can use it in the backyard, the front yard, inside, outside, you name it! I can take it with me to the campsite when I go wheelin' too so everyone in the camp has a welder. At the local 4x4 show, a guy welded the link mount back on his Toyota tuff-truck with my welder, in the parking lot!!!
Big MIG machines are GREAT, but, nothing beats the versitility, and portability, of a 110 v wire feed machine!
Chalk this up as wanted the 175, settled on the 135, and pleased as punch ever since.
[ QUOTE ]
[/ QUOTE ]
That is completely false. Penetration has nothing to do with the style of welder you're using. You probably were just trying to do something that a 110 volt MIG just isn't capable of. A good, 220v MIG will produce much higher quality welds in heavy material than any stick welder, and with flux core, proper preperation, and multiple passes, a 110 volt machine can still get the job done in most cases.
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]Not when you have a 400 amper 4 cylinder gas powered stick welder.
/forums/images/graemlins/rotfl.gif /forums/images/graemlins/thumb.gif
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Stick welding is dirty and difficult compared to MIG or FCAW. I wouldn't trade a good wire feed for anything.
Once you get the hang of it, you'll never go back to stick. I used to be the biggest stick welding fan--not anymore.
Cool you guys answered my question before i even asked it! /forums/images/graemlins/waytogo.gif
[ QUOTE ]
[/ QUOTE ]
They both have their advantages and dis advantages. For what most of us do, a MIG is fine.
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
Yep, agreed 100%.
Where's trusty and baddog and kidjethro when you need them?
I don't know I was hoping to get their opinions in here too /forums/images/graemlins/thumb.gif /forums/images/graemlins/peace.gif
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]I have 100's of hours of experience welding between stick and mig. I prefer a stick welder because like I said, it just seems to have more heat there because I use 5/32" rod, much thicker than mig wire. As far as how the weld looks....I don't care in most cases as long as it is a GOOD weld and even then, when the settings are correct splatter isn't bad.
