i'm glad you did rene. Ours is this. Take 2 pieces of 3/8 plate and chamfer the edge to be welded 22.5 degrees on each one. Put a backing plate on the back side, and tack it all together with an 1/8" gap betweem the two pieces at the bottom. Then weld it vertical uphill with 5-7 passes. grinding between welds, but the last weld cant be ground. The last layer of welds can't stick up more than 1/8" above metal surface, but can't be burned in below the surface either. Yeah this test will kick my butt. We do really good work at the shop, but we've been all running vertical down. Right now out of 12 welders, there may be 5 that could pass this test today, myself not included. Gotta practice practice practice!
Sherman, Tx
<font color=red>Come Awn yall...Let's go to LUCHENBACH, TEXAS!!!</font color=red>
<P ID="edit"><FONT class="small">Edited by laketex on 08/16/01 02:01 PM.</FONT></P>
