Well can i get a joint around here?
KansasTwister
Lawrence, ks
So I found the noise in the k5, rear u joint on the axle side is toast. So planning on changing it at the transfer case and the axle side. Should be a gm s44/3rl on both right? Is spicer the best to go?
Stock 86 k5 with 700r4/208/10 bolt.
tis what I would do.
Gonna look tomorrow to see if it has the factory plastic in there, but i assume it does because everything else drive train wise on this truck appears stock.
Would an inside diameter caliper be the only way i could tell if the join is a 3r or a 1330? (i think that's the close size one right?)
