Is the noise on there on one specific gear or all of them? Is the noise there in neutral with the clutch pedal released? Does it go away when the clutch pedal is down?
I’d also wonder if you have a heat shield or something grounding out on the trans or t-case that could be the source of the noise.
Trying to take the cover off now to see how it looks inside, the right stuff has a death grip on it though.
