I can't believe what a pain in the a$$ it is, trying to accomplish anything in my area,as far as auto repair--we have every parts store you can name within a 5 mile radius,and many more not that much farther away,but it seems like you cant buy a dam thing,even if you have the money.."we dont stock that--might be able to get it tomorrow,etc"..
I've spent 2 days in 90 degree heat and humidity lying on my aching back,trying to fix the front right exhaust pipe on my '82 GMC 6.2..it rotted off right at the flange and couldn't be fudge patched once more,and I've had sheet metal from aresol cans and hose clamps wrapped around it for a good year (and they still look like the day I put them on too!)--but wanting to do things right,I decided I had no choice but to be brave,and try getting the nuts off the manifold studs --the manifolds look like they sat on the bottom of the atlantic for about 75 years..
With the aid of my torch,I was able to get the nuts off,one was so whittled away I had to use a 1/2" 6 point socket to grab it..was lucky it came off fairly easy..the studs someone used were the type with only 1" of threads ,the rest smooth,intended for the "springs",which it doesn't really need..
One manifold stud hole ,the inner most nearest the engine,was a blind hole,which had a bolt in it,rather than a stud..I lucked out and it came right out--I think I actually put it there 12 years ago when I got the truck,and used never seize on it..
Now the dilema is the threads on the studs,one out of the 3 in particular,have rusted away where the old nut sat--so a new nut wont tighten..but there are threads further up that are intact..
I'm using 1/2" nuts for spacers to take up the "threadless" area on the studs,where the springs would have went....
I would just replace all 3 studs,but I am certain attempting to heat the manifolds up and get them out will result in disaster--the manifolds are very thin where they go in,and if I muck them up,I will have to pull the engine out in order to get the manifolds off,the bolts are now rivets,and I sincerely doubt they would come out of the cylinder heads even if I cut the bolt heads off and pry the manifolds off (which cant be done with the engine installed--they are practically touching the frame rails..)
I think I can get by with the existing studs, if I use those longer nuts,like ones used to join threaded rods together,or the brass ones used on exhaust often..
The next dilema is I'd like to buy a new exhaust pipe flange--the original could be re-used,but its kinds crappy,so are all the other 3 bolt ones I saved off 350 exhaust pipes that will fit perfect..
I've called no less than a half dozen stores including NAPA (the triple the price of usual parts stores place,but they usually HAVE the things no one else does)--no dice..no one has the flanges I need "in stock"...and I'm not 100% sure the ones I look up online are an exact match to what I have--it'd be nice if I could walk in and match one up,you know ?...no,that would be too easy..so I'd have to "special order" them and wait a day or more,then have to eat them if they wont work--here stores policy is "no refunds on special orders"...which bites..
You used to be able to get a pipe that had the flared "donut" gasket end with a 3 bolt flange on it and a 6" "stub" to bolt right to the manifold at every parts store around here for under 15 bucks....now all those seem to have gone the way of the dinosour..I dont even see them online !..
I need one of those 45 degree elbows to make the front pipe up with--thankfully those are still available...
The worst part is now I have the truck apart,its my only means of transportation,so I'll have to walk or beg someone for a ride,and I'm sure the closest parts store wont have all I need ,and I hate to have a neighbor haul me all over the county to find the stuff I need..
I should have headed right to the junkyard before I took the truck apart..
I bet there, I could have just grabbed a pipe & flange off a truck with no engine in it,or found one in their pile of cut off exhaust pipes..
I was stupid to start this job without having all I needed already..
I'm tempted to attach my plates to one of my other vehicles,to get to the store or boneyard,but with them being in worse shape than the truck is,and with no current inspection sticker, I'd likely get pulled over as soon as I pull out of my driveway...
I hate having only one registered vehicle..I'm used to having a least two,and have had as many as 4 of them at my disposal..wishing now I at least had a motorcycle or bicycle...
I may have to pull a George Jones and use my riding mower !..a taxi would cost more than all the parts and labor to fix the truck would too,so thats not an option..
I may not even be able to finish this job now,my back is wasted from lying under that p-o-s for the past 2 days...
..I was stupid to start this job without having all I needed already..
