What are these?
In my underwear
Administrator
Author
CO
Before I start a voyage to find out where these 3 lines go, any ideas?
They look like vacuum lines?
This is on my 72 Blazer that now has a TBI 350. They are coming out of the firewall just to the right side of the motor.
do you have a hvac blazer ?
and the 3 lines are not hooked up now so they do nothing .
Original non AC body. I haven't looked under the dash yet to see if they are hooked up to anything.
Those are for the windshield washer.
One line from the reservoir, 2 out to the nozzles. The original pump is on the wiper motor, under the dash.
I believe that this is the driver side of the engine and the wires below are the ones going to the taillights.
Picture of a '69 C10. The big block hides things a little bit. View attachment 520052
I will have to revisit this after I replace the coil and all the other crap I find. My washer stuff is setup different and appears to have been changed over the years.
Yep, good chance that it has been changed to an electric pump. I did on my '70 and there used to be small inline pumps available at the parts stores.
