what cam, and stall with 4.10's
francis
kemp, texas
hello everyone, I am a 20 year old tech at a local shop and have worked on no proformance vehicles, and have no clue what to do here. I am the proud owner of a bone stock 87 tbi blazer. The trans is out right now (good ol' 700) and the truck sat a while before I bought it so it needs to be run to get the computer to "relearn". Anyway I have managed to get a hold of some vortech heads :D so they will be going on the truck. But what do I need to run as far as cam and converter? I want to run about 38.5 swampers and go play in the mud so i'll need a bit of torque. The rear will be a D70 and whenever I find a D60 front it will go in. the rear has 4.10's (I think) and if it does not hay hay 4.56's here we come.
by "converter" are you referring to torque converter?? and remember, the Vortec heads gotta have the tbi-vortec intake manifold- as far as i know there's only a couple around. and i know nothing about cams.. good luck..
If you wanna spin those big swampers in mud find a BB. A built 454 would work like a champ. With those size tires I would definately be looking at 4.88's. I ran 4.56's with a 700R4 tranny turning 35's and it was perfect. 4.10's are for 33's and 35's without OD.
I hate stall converters. Make it a pain when trying to go slow. Like parking lots, stop n go traffic, and slow moving on the trail.
For Cams, call Comp Cams or check out the websight. They will ask you 50 different questions, (or you fill out a form) and they pick the perfect cam for you. Or look at Lunati's Voo-Doo cams or Comp Cam extreme energy or 4x4 cams. Probly want something around 214-218 duration @.050 with mostly stock components. And Edelbrock makes Vortec intakes.
My 388 stroker with aluminum heads has a 230/236 degree duration cam at .050. Since the motor is bigger it can take a little bigger cam. But its also built for upper HP since the motor was originally intended for a 72 Nova. (Dont ask). My converter is only a couple hundred higher than stock, but thats just because with this cam I dont idle at 600 RPM. Im idling at about 800 RPM in gear.
I think probably the most important thing to look at when picking a cam is to match the cam's power range to the stall your going to run. Basically you need to decide where you want your power range. Then pick a cam that satisfies that, and match a converter to it. Just know that stalls make a lot of heat in your tranny and its probably gonna get annoying having your engine revved up all the time just to move slow. BTW buy a BIG tranny cooler :D
