Stay away from the 770 truck avenger. I love Holley's and I know them well, but that particular carb does not have high speed airbleeds and it will be a constant compromise. I changed jets, pump cams, accelerator pumps, vacuum springs, etc. I got it running much better but the fuel curve is still way off because of the lack of air bleeds, and there is nothing you can do about that, without air bleeds.
Vacuum secondary carbs are less sensitive to being too large, because they only open based on airflow. Double pumpers are a little more sensitive, but generally have better throttle response and power when tuned correctly.
