I had better luck with the street avenger than the truck avenger, even on the dunes and hills. The truck avenger sucked. Actually the custom double pumper I made myself from piece of carbs was way more fun to drive.
I can get Holley, Edelbrock, or Jet carbs. Or other race carbs but not applicable here. It sounds like a Qjet won't fit your intake anyway.
You could get a street avenger and put a fuel hose to connect the vent tubes and cut a couple slits in the top of it. You could also add jet extensions and a notched float to the back bowl.
If you are tuning your engine to run well the timing at idle is only going to tell you how well it idles. That should be tuned after the WOT timing by limiting the mechanical and vacuum advance.
I recommend you disconnect the vacuum advance temporarily, rev the engine to 3000 - 4000 RPM, where it has the max timing, and then set the timing there to about 34 degrees. Then reconnect the vacuum advance to full manifold vacuum, not ported, it will like it better. If the timing is causing issues it idle you need to limit it with the weights, not change your timing at WOT to help it idle.
If you do end up getting a new carb, I would be happy to ship one to you. Or EFI, and kiss the carb issues good bye. I have a BBC PF4 in stock....
I also have Holley parts in stock to make a whole kit while using Edelbrock or Holley intake.
OR we can get you a terminator X stealth system to bolt onto your current intake. That computer will work with MPFI as well if you upgrade down the road.
I also have Holley parts in stock to make a whole kit while using Edelbrock or Holley intake. OR we can get you a terminator X stealth system to bolt onto your current intake. That computer will work with MPFI as well if you upgrade down the road.
