went to the the permatex site...
[ QUOTE ]
Permatex® the Right Stuff® Gasket Maker
Return equipment to service immediately when you make leakproof gaskets in just one minute with the Right Stuff.® This latest elastomeric rubber gasket technology is blowout resistant and outperforms pre-cut gaskets. Specified on production lines by GM, Ford, Daimler-Chrysler and Mercedes-Benz. Temperature range -75°F to 450°F; (-60°C to 232°C) continuous, 500°F (260°C) intermittent; resists ATF, coolant, oil and other shop fluids. Protects against leaks caused by vibration and thermal expansion. Sensor-safe.
Suggested Applications:
Automotive and marine gaskets, valve covers, gearbox covers, pumps, compressors, oil pans, thermostat housings, water pumps
[/ QUOTE ]
[ QUOTE ]
PERMATEX® ULTRA BLACK® Gasket Maker
For dealership warranty requirements, insures extended drivetrain warranties compliance. Fast-curing formula. Sensor-safe, low odor, non-corrosive. Meets performance specs of OE silicone gaskets. Retains high flexibility, oil resistance properties through use of a patented adhesion system. Temperature range -75°F to 625°F intermittent; resists auto and shop fluids and vibration. Also available in AUTOMATIC TUBE® dispenser.
Valve covers, oil pans, intake manifold end seals, timing covers, transmission pans
[/ QUOTE ]
[ QUOTE ]
PERMATEX® ULTRA GREY® Gasket Maker
Designed for high torque applications (predominantly Japanese designs) requiring a unique RTV gasket. Exceeds manufacturers’ performance requirements. Low odor, non-corrosive. Outstanding oil resistance. Guaranteed not to leak. Temperature range -75°F to 625°F intermittent; resists auto and shop fluids and vibration.
Valve covers, oil pans, intake manifold end seals, timing covers, water pumps, thermostat housings
[/ QUOTE ]
[ QUOTE ]
PERMATEX® ULTRA COPPER® Hi-Temp RTV Silicone Gasket Maker
For 4-cylinder, turbocharged or high-performance engines. The most advanced, high temperature RTV silicone gasket available. Sensor-safe, low odor, non-corrosive. Superior adhesion. Three times more oil resistant than conventional silicones; eight times more flexible than cut gaskets. Temperature range -75°F to 700°F intermittent; resists auto and shop fluids and vibration.
Exhaust manifolds/headers, valve covers, oil pans, timing covers, water pumps, thermostat housings
[/ QUOTE ]
[ QUOTE ]
PERMATEX® Sensor Safe Blue RTV Silicone Gasket Maker
The original Blue. Will not foul oxygen sensors. Replaces almost any cut gasket. Makes reliable "formed-in-place" gaskets that resist cracking, shrinking and migrating. Coats pre-cut gaskets to increase reliability. Temperature range -65°F to 500°F intermittent; resists auto and shop fluids. First generation 1970-1980 gasket maker. Also available in AUTOMATIC TUBE® dispenser.
Valve covers, oil pans, timing covers, water pumps, thermostat housings, transmission pans
[/ QUOTE ]
[ QUOTE ]
PERMATEX® ULTRA BLUE® No Leak RTV Silicone Gasket Maker
PERMATEX® Ultra silicones were developed to meet today’s technology changes. Sensor-safe, low odor, non-corrosive. Outstanding oil resistance and joint movement values. Eight times more flexible than cork/composite gaskets; three times more oil resistant than conventional silicones. Temper-ature range -75°F to 500°F intermittent; resists auto and shop fluids and vibration.
Valve covers, oil pans, timing covers, transmission pans, differential covers
[/ QUOTE ]
/forums/images/graemlins/thinking.gif none of these say avoid such and such metals
Doesn't even list the red type
