wetoolowdingbangow
Ok so ive recently swapped in a 14 bolt ff in place of my semi float. Ive run into several issues as usual.
Im still running an np208 so I have a slip yoke and it worked at an appropriate range when the semi float was in. My pinion angle was horrendous though so I started fresh with new perches on the full float.
After bolting up the axle with the perches loose so I can rotate the axle and center it. I noticed the drive shaft is about 4 inches short now when the axle is in the proper position angularly. On top of that fun im binding now. When the axle is pitched up at 10 degrees I gain some distance and theres less binding. So to hell with proper pinion angle? im not sure what to do here. Its obviously a combination of things here thats making life difficult. Should I lengthen the drive shaft and run the unfavorable, non binding pinion angle? This truck isnt a daily driver and will be trailered to the trailer. I may do an hour drive here and there.
I'm not sure where ive accrued this large of an error. I went from lift springs to 56s, zero rate in the 1 inch back position and a shackle flip. I've measured the center pin location on the leaf spring and I know im in the right area. I also measured the wheel base which is 108 ish (d60 pushed forward 1.5") which means im where I should be.
You would have to have quite the lifted rig to have 10 plus degrees of pinion angle.
