What do YOU have to do
blazinzuk
Buzzbox voodoo
Rexburg Idaho
to be ready for blazer bash 2011.
Me get 2 seatbelts for the back
Build a top
Change out front springs
Change out steering box
Actually attach the front fenders better then they are.
Put on my new fancy bumpstops
Build a traction bar
Make my lights function once again
Put my new grille in
What do you have to do?
Check the oil
Put in some gas
is all I have to do
cut fenders
measure front drive shaft
remove doors
is what I will probably do
Unfortunately - nothing...:(
x2, cause I can't go :( I'm "closer" to going than last year, but not even "close" to capable. :doah: So I'm getting ready to see some videos and pictures from other members :thumb:
you really want me to make another list?
Just ordered driveshafts today.
Complete body mounting and cage bolt up.
Build driveshafts
Figure routing for PS/hydroboost hoses/ Make hoses
Fabricate oil coolers lines
Install wiring…help JEFF
Route and fabricate front brake lines
Install rear brakes
Bleed brake system
Engine:
Install temp sender
Install oil pressure sender
Install radiator core support
Figure overflow bottle mount
Install shifters/linkage
Engine start up
Check trans fluid @ startup.
Check cooling fan operation.
Check for oil cooler leaks.
Front Dana 60 axle:
Check all lugnuts for proper application
Torque all fasteners
14BFF rear axle:
Body/Frame/Suspension
Install Hood/tailgate
Modify front fenders for tire clearance
Seating....
Seat belts...
Vent all drivetrain w/tubing
Valve cover venting/PCV setup/ check hole grommets for fit
Vacuum advance source
Vent gas tank/tipover valve
Misc. items
Install windshield
Install rear roof section
Mount front winch bumper
Mount 9.5XP winch
Install winch fairlead
Figure winch cable routing
Fab and Mount midframe skid plate
Fab and Mount fuel tank skid plate
Mount spare tire
Install rear brake valve handle
__________________
Wish list
Fab fire extinquisher mounting
Figure trans temp guage placement and needs
Figure Hi’lift mounting
Figure and fab mounting for coolers, spareparts, toolbox, tote bins
Fabricate rear battery mount
Fabricate 1.5” Tube grille
:haha: I pulled the blaze off of the trailer after BB last year, and its been sitting ever since. I have just been collecting parts for the big build. Im gonna run the blaze as is for now. Im getting close to assembly though. Just not this time around.:o
Since the buggy was pulled into the shop in April after being cartwheeled a few times it hasn't been touched.
Planning to look at it some tonight, I know that at a minimum it needs a few cracks welded up. Maybe a new roof?
Just a few minor things:whistle:
Dropped off front drive shaft today. New one installed and working good.
limit strap in front—done
put big block tbi on and grind out intake to match.- done
data log for new tune and burn chip
finish exo
organize spares
build new rear shackles
probably new/used rear leaves
not to bad considering
oh and buy 2 new batts :doah: only had to buy one!
Pritchet on Sunday my freind?:waytogo:
Didn't have anything major till last night, now gotta fix this.
Finish my LQ4 install
replace my power steering pump
finish dovetail
re-do the rear of the roll cage to accommodate the dove tail
new rear shock mounts
install hydro bump stops
put everything back together and take it on a good test run
fix the trailer brakes
install pump rub repair on the tow rig
There are a bunch of other minor things too, but those are the big ones. Right now it's still up in the air if I'm going to make it or not :dunno:. It depends on how many other "issues" I have before then.
Here's how it's sitting now
It wouldn't be so bad if it weren't 110+ every day
Lets see:
finish mounting fuel tank
add reservoir to power steering
lengthen rear driveshaft
build front driveshaft
finish seat mounting for the cage
mount front shock towers and shocks
rear shock in-boarding kit and shocks
finish wraptor (weld the two tubes together)
make transfer case side mount
wire up winch
wire in offroad lights (front and rear)
finish relocating batteries
install transfer case shifter
install windshield
mount transmission shifter
build a skid plate
install fuel injection
cut fenders
install CB
Thats just for this week :rolleyes:
Build another x-member for my new doubler, thanks ORD
Install easy inch
Swap front shackles from my 78
Install new ORD steering box brace
Paint and install my new DIY4X tube doors, thanks DIY4x
Paint roll cage
Install 14b gaurdsman
Paint and install, new GLO 60 and 14b diff covers
Electric fan
CB
Fire ex
Test run :D
If I have any time left,
14b disc conv
Rhino line the inside
Rear tube bumper
Fuel cell
Right now I am installing new power steering pump and putting in radiator that was just gone thru. I will throw a new serp belt on at the same time. Found some big mud clumps from when I did a mud run like 3 years ago on father's day.
