garydan
It looks like oil dripping from the spark plug?? Its not coming from the valve cover, its clean below the valve cover gasket.
Click here for a fullsize pic: http://garydan.no-ip.info:8080/k5blazer/DSC06547.JPG
looks like you're right.... how's it run? can't imagine very well
Was it just loose?
Smoke when you start it up?
It's a 400ci motor. This was the third plug on the passenger side (counting from the front of the motor) come to find out that plug is a real bitch to tighten. Looks like I need a new tool. You need a universal joint to tighten
It, but once you get it snug you can't get the universal joint off the plug socket. It was stuck up against the header. I need one of those flexible extensions or a shorter Universal joint.
It didn't seem loose when I removed it though.
What are you talking about it was a bitch to tighten? You were able to get a camera up there, just tighten it from the bottom, the same way you took the picture.
