what goals do you have today?????
get a ride to autozone....heh.
they close in 2 and 1/2 hours.
I need to get my intake gaskets, header gaskets, and collector gaskets on then cut my exhaust and weld it up to clear the t case, then change my oil twice to clear out all residue from whats left of the water in my oil(not much). After that i need to get the new fan shroud in, mount up the radiator with the correct mounts and then i have to find out why the hell i don't have power. probably the a fusible link on the firewall.
I love wrenchin...
I need to get my body on right and bolt down what i can. We just about had the cab lined up today by i got the wrong length bolt and the hardware store was closed. So i drove my truck around the block, did a burnout and now the bolt hole is way off. Then i have to replace all 4 rear spring hangers because they're rotted out and move the gas tank to the right side so i can fill it up. Later this month ill be doing a motor swap and then i can finally get around to putting my lift on. Lots to do but not much ambition.
Later
in order:
1) finish mohave heater install
2) relocate battery
3) 52" spring swap
4) narrow the front
5) narrow the rear
6) new front wincher bumber for the 8274
7) new rear bumper
8) chop the top
9) cage
10) drive.
j
well ihad planned to staighten up around my house, then wash my k-5, went to redding friday to pick up some 14blts and now i can't see out my windshiled because of all of my bug guts, then i was gonna do some interior work...but instead i spent the day in the emerengcy room with blood poisioning...yea!:mad:
I got my goals done today . Resealed power steering , watched justhorsinaround weld my frame ( must of been an old crack , found when pressure washed to find leak ) , drove home with no leaks after god know how long :D
