What hubs??( went mile marker supremes)
Best hubs
  • Warn standard
    Votes: 14 51.9%
  • Superwinch
    Votes: 1 3.7%
  • Mile Marker
    Votes: 6 22.2%
  • F*** 4x4, run through the snow nekkid
    Votes: 6 22.2%
  • Total voters
    27
  • Poll closed .
I took the nuts off to clean the grease off and retorque them. the outer one was loose for some reason
DONE! d*mn hubs. 30 min job turned into 2 days:doah:
My problem was when I went to take them off the Allen head screws stripped out our broke
:whistle:
:hack: :saweet:
Do I really need that "nub" on the inner hub nut? Mine broke off a long time ago :eek1:
if a wheel bearing starts to seize it can grab them nuts and spin it all off supposedly:dunno: i dunno. as long as the washer is between the nuts still i dont see how it could
check your wheel bearings, they will loosen over time with out the tit. not much but enough that you don't have proper preload any more
So that's why I'm always going through wheel bearings... :doah:
I just installed mile marker supremes on my 6 lug 10 bolt 85 k5. Easy install and they work great.
