I had nothing useful to add but curious of the outcome
I did pick a good user name though
Is @K30Blazer going to become FlipperK30?
Whatever is eventually found, I bet the damage was done during recovery more than the actual roll itself.
I don’t care who you are…..that is a hard landing! I’d be looking real hard at the passenger’s side rear spring pack
And Merrick….dude, WTF? If all things in the world to pull your beast back on its wheels why in the world film a Ford Raptor of all things when there is a cherry old Chevy right there to help a brother out!![]()
The axles have to be parallel to start with. Crawl-walk-run. Fix this first. And check the sector shaft for cracks or a twist just for safety. Make sure the steering arm studs are good and the knuckle top is not cracked for the same reason. This stuff will kill you. A bent frame or axle or a lot of the other possible problems will not.
