What is a 6.0 liter worth?
LVJimmy
Lost Wages, NV
I know someone selling a 6.0 liter out of a 2004 Denali. It has 32K miles comes witha all acc., transmission, xfer case, drive shafts, harness and computer. Any idea what this is worth? I would like to install in my '70 Jimmy.
if it were me selling it I might go a little higher than that. You see engine and trans(2wd) going for like $2-3k on Ebay. THe transfer case and driveshafts are of course no use to you. The 2500HD transfer case is too large and has to get slip yoke eliminator kit, on the FRONT, so forget that piece.
I'm not positive but I think it is out of a 1/2 ton Denali. I knew the driveshafts weren't much use but I didn't know the transfer case had a slip yoke.
no idea what tcase that would have, but it would be driver side drop either way, so you would need a Ford front axle. Personally I'd lose the Tcase and just run a 241 from a K5. err well from something with a 32 spline output on the transmission.
