Maybe....
I have seen only a few motors with the "ears" broken on the block where the starter bolts go welded successfully,even then its a good possibility it might not last..blocks are cast iron with high nickel content,and dont like to be welded,and the welds are fairly brittle,even when done correctly with the proper welding rod..its not a common problem,but it does happen unfortunately..most motors I've seen welded didn't last...
I've found the best way to measure the clearance between flywheel and starter drive gear teeth is to not measure between the gear teeth--(as explained earlier,its hard to get the drive to engage the flywheel and then try to measure,you need four hands!--there is a small hole in the starter nose on the bottom you can put a small screwdriver in to force the bendix out into the flywheel,but its difficult to do,and measure the clearance at the same time..)
What I've done was follow the directions that came with a rebuilt starter--it said to measure between the SHAFT the starter drive slides on,and the OUTSIDE of the flywheel teeth--a 1/8 inch allen wrench or drill bit is the correct distance to be had there,I've used that method many times and the starters always sound good..its just a different way of measuring the clearance,and its MUCH easier than screwing around trying to hold the starter "engaged" and trying to measure between the gear teeth...its always worked for me...
Be aware many GM starters "look" the same,and will bolt on,but the noses are just slightly different enough that they wont work!--many times on the "straight across" bolt pattern starters,a buick 231 V6 starter finds its way onto a small block--and while it WILL start the motor,it will grind off the teeth some every time,no matter how perfectly its shimmed!...I see this a lot..later 305 and 350's have the nose "tilted" at a different angle too,may or may not work on older motors properly..
Also a caddy "staggered" bolt pattern starter will bolt on a chevy motor and work,but I have heard the caddy uses a weird tooth count flywheel,like 166 teeth instead of 168!--again,it WILL work--for awhile!--then you'll need a flywheel AND another starter!..
Might be best to start fresh with the correct starter listed for the application it belongs on--go by what the engine came in originally,not what vehicle its in now--most chevy's use the same starter,but not all!...and pray the rebuilt one's core was properly identified,I see lots of them that are wrong--too many people think all the "straight across" ones are all the same--ditto for the "staggered" ones.
.GM has a lot more starter noses than most mechanics realize...I tend to keep the starter that came with the motor if it was working good,and rebuild it myself with new brushes and bushings--or just keep the nose and swap it onto the next one..
