What is the best way to fix a DS that is...
CUCV2
5/4 ton fun
New England
Too short?
Here's the skinny. I am lifting an 86 shortbox chevy with a shackle flip and installing some 64" springs. I got it all together including a 5 degree shim to correct the pinion angle and now my DS is too short. My Q is my subject title.
The options I am currently considering is:
1- A 5 degree angled zero rate from JKW Offroad
2- New CV DS from HAD (holy acronymn Batman)
3- Try and find a longer DS in a junkyard
4- Use a 1410 conversion ujoint and change the pinion yoke for a little extra length?
Not real sure about the validity of these ideas and would like some input from others. Thanks in advance.
how much are you short by? if we're talking 1 inch or so, the zero rate may work, but pretty much anything over that and you basically need to have your shaft lengthened.
Shouldnt be too expensive, $100 to $150.
Also, no one makes 1410 conversion ujoints, you would have to install a 1410 yoke on the DS and a 1410 yoke on the axle ($70 to 100 each, plus the joint)
DS is short by about an inch. Are there any other options to consider?
does that allow for correct extension/compression? IE: if you bolt it up, splines are barely showing, and shortening wheelbase 1" or 1.5" would get the driveshaft to correct lengh, still allowing roughly 1.5"-2" for compression (assuming a normal amount of flex)
If and only if you have this situation, a zero rate can fix it, otherwise, you need to have the shaft lengthened. Take a yoke to yoke measurement and take the shaft in to have it retubed. Based on a yoke to yoke measurement of the truck at normal ride hieght, the shop can figure out the correct length to make it for compression/entension
The DS is out of the TC 1" to 1.5" further than stock. The TC actually leaks fluid now so I would say it is out too far. I'm going to go to the local machine shop on Monday to see what they would charge to retube it. I like the axle right where it is so a zero rate is not the first choice. The TC is going to get swapped out later for a SYE type setup and a CV DS but I'd like something to get me through the duration. Are the rear DSs any different in length between an automatic and a standard?
Fwiw
FWIW, a trip to the junkyard provided the solution. It turns out a DS out of a 93 Chevy shortbox is 1" longer than what was in my 86. The splines even match up. There were a few differences but it is a bolt in deal. The differences were that the diameter of the newer DS was smaller and the ujoints were both 1350s but of a different design. The 86 has the retaining clips on the outer ends of the joint, while the 93 had the retaining clips on the inner ends of the joint. I was pretty psyched to find it.
