I have the exact same intake on my 6.2. Might of even come from the same place.....some guy won a random auction that a whole bunch of these new intakes still in the box with parts tags on them.
However, they are not a 100% direct bolt-on.
You will notice the two mounting feet cast onto the upper rear intake runners that are not present on the older 6.2's. Not sure but I think they were there to hold the big plastic cover over the intake found on the 6.5 turbos. I had to cut/grind both off as they interfered with the vacuum pump. I also had to grind a little bit off the front edges where it seats up around water pump/t-stat stuff.
Not a big deal, but took me much longer because it was a lot of "why won't this thing seat all the way down" moments.
I also gasket matched the intake just like mentioned above. Also had to drill out the mounting holes in order to get the bolts in as mentioned in the sticky article, but doesn't sound like that is unique to this particuliar style of intake.
