What is this???
Hempinfool
Registered Member
Havenot NC
I am trying to figure out what this is and what it does. I looked in the repair manual and LMC catalog but no luck. I see pictures of it but there is never a label. It is located on the driverside firewall and has 1 vacuum line attached. It is spherical and slightly larger than a softball. Thanks for the help.
I guess I need to learn how to properly post a picture. Hopefully it works now.
Thanks for the answer because I wouldn't of thought of it and I was ready to cut it open to see what was inside.
Yep, definitely the vac reservoir. I just put a new one in mine, got it from O'reilly.
Why did you replace yours? I disconnected mine trying to find a vacuum leak and I can't detect a difference in the heater vent operation. But then again, who is worrying about checking out their vent operation while their foor is in the gas? Is there any other worthwhile use for this reservoir?
I replaced mine cause it was cracked and I couldn't get the air to change from floor vents to dash vents. Once I swapped it out, all worked perfectly.
