What kind of computer.....
84CUCV
3/4 ton status
NJ for now
Well, i need one to plug into my 91 k5 so i can see what is up with it. Are they just about all the same or is there one kind i should go for. thx guys mike
Do you mean a scanner or a laptop to run WinALDL?
'Scanners' are either cheap and basically just read codes, which you can do from your SES light anyway, or they are expensive ones like a tech would use. These ones are by far the best but very expensive. WinALDL run from your laptop is very useful as are several other programmes, but it's free!
What problems do you have? Have you read the SES?
Yea, i need a scanner. my light comes on at high speeds and the speedo does not work. After the light is on for a while it goes out. then the speedo just jumps up and down and the e brake light stays on. I have no idea where to start with this. What is winaldl and ses mean. thx
Winaldl is a downloadable programme to run on your laptop which allows you to watch all moniterable engine data. SES is just your service engine soon light....the one that's bugging you!
How much is Winaldl and where can i get it? sounds like agood way to go. thx guys
