What master cylinder set up is this?
In my underwear
Administrator
Author
CO
Saw this in a 70 K5, what kind of master cylinder set up is this?
looks like aftermarket bracket to firewall for hydroboost with a older car size/style master . might be set up for 4 wheel disk on 1/2 ton size parts .
Looks like the old master cylinders for 4 wheel drum brakes with equal size reservoirs, but that truck probably doesn't still have drums.
That is a hydrobooster, but it's not the standard one that GM used in square pickups. This one has a longer nose and is rotated 180 degrees.
Here is what mine looks like.
6-2-intake-jpg.156507
Not sure what all the P30s got for boosters, but my brother's '82 P30 uses this same booster.
You can get an early Corvette master cylinder for 4 wheel discs or disc/drums that looks identical also...also there is a manual version for both with a 1" piston...
Looks kind of like a vette disc disc master. Probably mounted the hydroboost upside down to look cleaner under the hood.
The flange for the M/C on this hydroboost extends past the cylinder at the side. On our hydroboost units the cylinder extends past the flange (making it a little bit harder to get at that nut). I think it's something different.
I believe they used that m/c casting on drum brake equipped cars as well.
I have the 67 4 Disc m/c on my car.
image-jpeg.203504
