what motor is in my truck?
79mudder
Registered Member
Bonesteel
i got an 85 chevy 1/2 ton and dont know what motor is in it bought it and dont know if anyone has switched motors before me or not. i got the numbers off the front of the motor behind the altenator. they are caf331960 and marked over the top of them are numbers v1109tkk and those numbers are bigger than the other ones can anyone tell me what it is ? thanks
to tell if someone has switched motors, to the left of the waterpump behind the alternator on the deck surface of the block is a number, the last 6 digits of the number should match the last 6 digits of your vin. Mine does. to read casting numbers, just do a google search on the casting number on the block, and it will come up with websites that can help. Casting number is on the back of the block above the oil filter behind the head on the corner.
