I noticed on my truck that the passenger side tire appears to point to the right slightly and the drivers side one looks "straight ahead" if your looking down at the rims standing beside the truck ,but if you back away from the truck and stand about 20 feet in front of it,the tires appear to be pointing the same direction...an optical illusion?...I tried adjusting the tie rod to get both to look "straight ahead" by eye and using a 4 foot level across the rim,but after a short drive it was evident it was WAY off!......my alignment might not be "perfect" but after many trial and error adjustments of the tie rod and draglink,I've managed to get it to "feel" correct while driving (no pulling or veering around when you hit a bump,or tire squealing around corners),and the steering wheel actually is dead center going straight ahead for the first time since I've owned it!....using the two peices of conduit as a crude toe-in measurer helped a lot...I put them betwen the two rims before I adjusted anything ,so I'd have a reference point to start from,and after I got it done,it was real close to where it was when I started,so the toe-in was probably not that far off to start with..I might have a bit less than where it was originally...
