what should i get?
usafblzr
Newbie
arizona
i don't know what combo to run, should i get a 4'' or a 6'' lift?and should i run 33'' or 35'' tires. i wanna mostly mud bog and rock climb. thanks for the info.
35's will fit with a 4" lift, trim the fenders a little or put on some bigger bumpstops if the tires hit under full flex.
depends how deep your pockets are /forums/images/icons/wink.gif
a 4" and 35"s looks nice and is a really common set up. that's why i went with a 4" and 36"s to be different. lol! but a 6" and 35"s looks good too. however a 6" usually means new drive shafts and steering stuff. of course even the 4" requires a steering arm, that's usually included in the kit. if i were you i'd go with a 6" and 35-37s. you get a 4" now and you'll want a 6" later, i did and i do.
hmmm...get what you want. Look at my pic thread to see how trucks look with different lifts and tires.
