I'm swapping yokes. Need to get the right size socket, as I don't have one. What size is that nut?
For the record, I used a 1 1/4" socket from a Harbor Freight 3/4" drive set. No grinding was necessary. I have a Dodge Dana 60, so I don't know if that accounts for the 1/16" smaller size, but that's what it was.
Also, I put the Harbor Freight 1 5/16" socket on there to begin with, and noticed it had slop. I mention that only to indicate that the Harbor Freight socket might be a cheaper alternative for someone out there. I went from a 1310 yoke to a 1350 yoke today, FWIW.
This is very confusing. Harbor freight doesn't sell an inch & 5/16 socket. Inch & 1/4 yes however that will not fit a yoke nut. Please explain what you did in detail without rounding something out... This must be a "dodge" thing, which I have no experience with.
Well, I went over to owenst7's house, and his 3/4" drive set is from Harbor Freight. I put a 1 5/16" socket on my pinion nut, and there was some play, so I went and grabbed a 1 1/4" socket and that one fit very snugly. I wondered if the reason was that they were Harbor Freight sockets and they simply weren't machined very exact - then owenst7 suggested that it might just be because it's a Dodge Dana 60. Anyway, that's how it went.
The difference between the fit of the two sockets had a feel similar to when you are using a standard socket on a metric nut that's between the two standard sizes... kinda.![]()
. Didn't even break the 1.5" setting a 14 bolt crush sleeve (it fit that yoke just fine BTW).
