Are they 16" or 18" o.d.?
What? Never heard of them? Check them out below...Run flats? Interesting...
http://www.trailworthyfab.com/H1-Hummer-Wheel-Run-Flats/
Well, well, yeah, I see what you're saying but I've read and heard others call them runflats because they still allow the bead to remain seated so a 16.5" tire can still run flat without popping.I've heard of them, have a couple sets actually (rubber @ magnesium) . Never heard the PVC ones called anything but inner bead locks though.
What size? I think they need to be 6.5" wide to fit a standard H1 wheel. Care to cut one and see if it'll fit inside an H1 wheel if you have one?
We need to call you Sargeant Obvious, next in line under me."run flat" was the military term for the original rubber or mag inserts used by them, because of the raised center, if a tire were shot out, went flat etc you could continue to run on it till out of harms way. The factory run flats are no good for "our" uses because you can not air down with out the inside of the tire constantly contacting the raised center of it. That is why you often hear of people using "cut down" rubber or mag inserts![]()
I'm not even sane enough to spend $200 for 4 pieces of PVC when I can go to the local plumbers and get them cut for less than a fraction of the $200 cost. Then I can do the grinding and smoothing of the corners/bevels myself instead.
