What to do
blazingboy
Georgia
Guys I am tired of the GM saggy butt. I have a 2.5 inch lift with 33's and the back sags bad what should I do. It looks like if I lift the back it may pull out the driveshaft. I thought about taking a leaf out of the front, but it will rub and I don't want to trim what should I do. I guess I could get me a 502 to even it out.
Do you have saggy butt like this?
You could do a search...but i like to type this so your lucky...is your lift blocks or springs? If its springs, do you have the old ones? If you do, take the overload off the bottom on the spring pack and bolt it to the bottom of the new lift springs, either right side up if you like to tow, or upside down for a better ride and more flex
