I have a D60 scavenged from a CUCV and I'm getting ready to start spiffing it up for install under my K5. Besides the obvious refurbish of brake components and sloppy tie-rod ends, (and cleaning out the housing/new oil) any other suggestions on what I should check out or upgrade?
I'd also like some opinions on my spring perch. It looks a little tweaked. Do you think it's bad enough that I should grind it off and replace?
....I was thinking CUCV 14bff.....proof that what you read on the internet isn't always right!
