What transfer case to go with?
rjkharry
Registered Member
Charlotte
I have an 87 Chevy K-5 with a 350 tbi with vortec heads. I am converting it to a nv 4500 5 speed transmission. I am installing an 8" lift probably going to run 37" tires. I was curious of what transfer case would be strong enough to hold up to moderate wheeling. :whistle: I have an 88 suburban that I am using as a perts truck. I am not sure what transfer case it has but it was rebuilt 18k miles ago. Would it be sufficient?
I know everyone said the np241 but am I taking a big step down with a rebuilt 208. I crawled under my 88 suburban parts truck this morning and that is what is on it.
208 should be fine. Gear your axles properly and put a skidplate under it and it ought to run well. Lots of guys on here are running them with no complaints.
If they made a slip yoke eliminator for a 208 that was a decent price I think it would be alot more popular.
208 is fine to wheel with
what will I need to do if I am lifting the blazer 8". Will there be any complications with the angle of my drive shaft.
The easy way is to drop your t-case,
I have run a blazer (albeit with a 203) with 10" of lift no cv at either end of the shaft and no vibrations. The yokes have to be perfect, which means you are going to have to lift the truck measure everything take the rear axle out cut and reweld the perches on it.
How are you getting the lift in the rear
8" springs will require you pay some attention to your drive shafts. You might get lucky with the rear, depending on your wheelbase, but prepare yourself to do something up front. Shims at the very least, new cv shaft at the most. Lowering the t-case will help with the rear shaft, but make the front angle even more severe. Not to mention putting more stress on your motor mounts, possibly putting your distributor into the firewall and less ground clearance. To many negatives for me.
When I put the 8" Alcans on my truck, the stock front shaft would physically stretch from the t-case flange to the yoke on the 60, IF I un-screwed the slip collar on the shaft and let it slide out enough to expose the splines, but the stock 3r CV wouldn't allow enough angle to allow the u-joint to sit into the yoke. We were due to have 16+" of the snow the next day and I needed to have a working front shaft just to get out of the driveway. So I busted out the grinder and went to town on the cv trying to get enough angle out of it to make it work. I managed to get it clearanced enough to bolt up, but even just static, sitting on flat ground it was absolutely maxxed out, at it limits. If there was ANY articulation of the front, if the passenger side dropped even a c*nt hair lower than the drivers side, the CV would have exploded. Called up Jesse over at High Angle and it's looking like for me to have a 100% relaible and wheelable front shaft, I'm gonna be lookin at one of the 42* cv's and 1410 joints at the axle. $800+. :eek1::1zhelp:
Eitherway, unless you want to be one of those posers driving around with no front shaft, or if you want to actually get out and wheel it, plan on spending some money on it.
Snow storm in question-
Besides, I'm always lookin for another excuse to pic whore it up.
Did the 241 come in a passenger side drop or driver only? If so what years of trucks were they in. Also what are most people running for shifters on the 241.
The passenger side NP241 came in our body style trucks 89-91 but only 89 has the old school speedo cable. 90-91 have a speed sensor and an electronic speedo.
88+ GM fullsize half and 3/4 tons uses a D-side drop NV241 that is basically a mirror image of our version.
Our body style, does that mean blazers not trucks. Also will the 90-91 years work with a speedo mod or should you stick with one out of a 89.
89-91 K5's and Burbs. Our body style 89-91 1 ton trucks got 205's.
Some folks have just swapped the speedo head off of a 90-91 Blazer/Burb into their older dash. I believe this is what tRUSTy did. Otherwise I bet if you got the parts you could convert the 90-91 t-case over to the gear driven style. Probably be easier/cheaper to just track down a '89 case.
