Whatchya building for BB16?
I feel like pinky and the brain
What are gonna build this year for Blazer bash?
Same thing as every year pinky.
So yah I have made very little progress
I have a "new" motor to put in.
It burned enough oil between Blazer Bash and the Spring Creek debacle that the lifters started rattling on the way home. Had to add a quart to get them to be quiet. It smokes like a fog machine anytime it's under load on the trail.
How many miles on the donor?
It was in a trail rig before this so it's low miles, actual miles unknown. It hasn't been run in quite a long time so I'm going to change out gaskets and run some oil thru it first. Cost me $250 and a little bit of horse trading.
I put together a list. It isn't in any order.
MUST BE DONE
  • TRANSMISSION
  • TCASE SHIFTER
  • WASHER BOTTLE/ WIPER BLADES
  • E-BRAKE
  • POWER WINDOWS/LOCKS
  • REAR BUMPER
  • TOW HITCH IN FRONT
  • TOW HITCH IN REAR
  • CB RADIO
  • CHANGE FLUIDS
  • ROCK SLIDERS
  • RADIO
  • CHANGE FLUIDS
  • REBALANCE REAR SHAFT
  • TRANS COOLER LINES
  • BREATHER LINES
  • T-CASE SKID PLATE
  • REAR PINION GUARD
  • ALUMINUM LINKS
  • ALUMINUM TIE ROD
WANTS TO BE DONE BUT NOT NECESSARY
  • PAINT/ BODY WORK
  • LIGHTS FRONT, REAR AND ROCK LIGHTS
  • ELECTRIC RADIATOR FAN
  • POWER STEERING COOLER
  • REAR SUSPENSION RE DONE
  • DIFF COVERS
  • SPARE DRIVE SHAFTS
  • TRACTION BAR
  • FRONT AND REAR AXLE TRUSS
  • SUBURBAN GAS TANK
  • TCASE CLOCK
  • A/C
  • BABY CAM PACKAGE
I feel like you are cheating and putting extra space between each line to make the list look longer..... :whistle:
:rotfl:
Ben, are you sure aluminum links and tie rod are a must? :thinking:
:D
