smokeum99ta
What's all needed to convert a dually dana 60 front rear to a single tire? Part numbers would be great too if you know them. Thanks.
"front rear" ? I never understood this terminology.
Anyway... To convert a front D60 from DRW to SRW you just need to swap the bearing hub/rotor assemblies, everything else is the same. Technically, you can convert the DRW rotor to be used with an SRW bearing hub by redrilling the stud holes but I don't know the bit size. The redrilling info is in the "D60 Bible" on Pirate.
Next time just replace the word rear with axle.Yeah me too. But that's the easiest way to explain it lol. Thanks
So are you saying the flange to flange "length" is the same? Pirate shows a spacer on the hub but they used the DRW hub. Does that mean a new SRW hub can be swapped in and it will work? (Call me "Puzzled".)
