I have one on mine. Just grab a tailgate, the lower mounts,the upper latches, and the limiting straps. Just take off your K5 stuff and bolt it all on. All the right holes are there and they go on in about 15 minutes.
[ QUOTE ]
Now I gotta come up with something to fill the gaping hole when the hard top is on... at least untill I get a soft top.
/forums/images/graemlins/thinking.gif
It doesn't get much simpler than this, a very simple bolt on, just get the hardware off the donor p/u.
[/ QUOTE ]
Damn that's sweet. Now if I only had the rear pillars left on my truck to attach it too... /forums/images/graemlins/doah.gif /forums/images/graemlins/hack.gif /forums/images/graemlins/weld.gif /forums/images/graemlins/grind.gif
How well does it line up while closed? I've been thinking about just taking the glass & regulator out of mine. /forums/images/graemlins/whistling.gif
they line up fine and look like they were supposed to be there! I used to have a pic of mine in my gallery, but it is gone now... /forums/images/graemlins/doah.gif
Now somebody asks the important question, how do you seal it. I tried the truck 'gate several years ago and went back to a stripped K5 'gate because of the seals. I got tired of sucking exhaust into the cab through the truck gate's cracks. I know you can weatherstrip it but it was just as easy to take the window and motor out of the k5 'gate and call it good.
I plan on weather-stripping it. I like the truck-style tailgate due to the easy removal... that and I replaced my tail pan (or what was left of it) w/ 3x3 steel square tube and don't wanna go through the pain of lining up hinges. /forums/images/graemlins/tongue.gif
Stripped K5 gate is still heavier than a truck gate though considerably lighter than a loaded K5 gate.
Since my rig will never have the top back on sealing isn't really an issue for me. Eventually I may have a simple canvas top made for winter rides but I decided it will be less headaches to just weather proof the interior and have an open back.
[ QUOTE ]
[/ QUOTE ]
Dude I still wanna see that chick... /forums/images/graemlins/whistling.gif
