Whats that!b
Post up some measurements of the intake port size and spacing. Maybe the bolt hole spacing as well. That should help somebody here figure out what engine it belongs on.
I only count 6 bolt holes per side you sure its a BBC?
I'm definately not perfect, so I could be wrong, but I'm pretty sure that's what it is. Some aftermarket intakes only come with the 6 per side. Mine only has 6. Here is an example of one.
It has 6 bolts as u said! But what does that mean? And as u see its injection , can i change it to fit carbo? :D for 350 engine? :s
No. Will not fit a SBC. Runners are really designed for fuel injection vs carbs. If it was for a SBC you could make it a carb setup for enough money, but it wouldn't be worth it IMO.
Sbc imo? :D
Small Block Chevy (i.e. V8 283-400). The Big Blocks are 396, 427, 454, etc. The SBC and BBC have different port geometry, so you can't swap an intake or exhaust manifold between them.
IMO = In My Opinion
